We're about to go camping and our battery life is less than a day. I've searched and looked on this forum, and have not found our answer, except perhaps there might be a short somewhere. We have a 2009 DM T@B. We noticed that our old battery could not seem to hold a charge, and so we replaced it 3 days ago with a deep cycle 27. The new battery is not holding a charge either. The only thing we know is "on" is the LP detector. We no longer have a pump, and our CO2 detector is now battery operated. The (new) thermostat has an on/off switch, as does the refrigerator. And so we have been daily tracking fuses. Pulling fuses to try to figure out what the draw is. With no fuses pulled, the draw in 9 hours is from 12.8 to 12.54. With the LP fuse pulled, the draw is from 12.8 to 12.6 (in 9 hours). With the pump fuse pulled the draw is from 12.8 to 12.54. With the "30 amp" fuse pulled the draw is from 12.8 to 12.66. And we couldn't test the refer fuse because it is on the same circuit as our battery tester. What would you do next? We have a new converter ordered (originally thought that was the culprit).
Ack- we're boon docking! we'd like at least a couple of days of life.
Thanks!
0 ·
Simply pulling the main fuse at the converter still leaves a potential (however slight) for current leakage somewhere upstream. Disconnecting the battery entirely leaves nothing up to chance.
Anecdotally speaking, a drop from 12.8 to 12.66V in nine hours seems a little quick for a brand new battery, but not alarmingly so. The bigger question is whether it settles in at 12.6V, or continues to drop at a significant rate. A fully charged disconnected battery in good health should hold a no-load charge >12.5V for several days if not weeks.
So it is safe for the battery to get to 11.9? Still in the green zone? I need to talk to my battery tester about that.
Battery life isn't an all-or-none thing; the more frequently and more deeply you deep cycle it (within limits) the more its life will be compromised. Conventional wisdom suggests that keeping it above 12.1-12.2V is best practice.
