Shore Power
PGSUtah
Member Posts: 9
My shore power isn't working. I'm plugged in but the Air conditioner isn't turning on. The AC fan runs. I assume this is because of the battery. The timing of this problem coincides with me changing out my one 12V for two 6V. Any ideas
The A/C is on it’s own 110 circuit. Try resetting the GFIC on the front of the bench. You can’t run the A/C off battery.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
OMG Yes. The a/c breaker needed to be flipped on inside the fuse box. Goodness! I swear I'm out of my element with this trailer. But I'm learning. It's running now. This will help cool me off while I try to fix my water pump! Thanks SAM
There is also a GFCI on the plug for the AC.
- Hash T@B Fun
@PGSUtah just think...you've got your first good campfire story! I did the same thing, no idea the power pole had breaker switches, and ran for two days on battery and propane! The plus side is now I know I can do this without shore power. Glad it was an easy fix!2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
