Shore Power
My shore power isn't working.  I'm plugged in but the Air conditioner isn't turning on.  The AC fan runs.  I assume this is because of the battery.  The timing of this problem coincides with me changing out my one 12V for two 6V.  Any ideas
Patsy S. 2017 Honda Pilot, 2017 T@B Outback 320S
    The A/C is on it’s own 110 circuit.  Try resetting the GFIC on the front of the bench.  You can’t run the A/C off battery.
  • PGSUtah
    PGSUtah Member Posts: 10
    OMG  Yes.  The a/c breaker needed to be flipped on inside the fuse box. Goodness! I swear I'm out of my element with this trailer.  But I'm learning.  It's running now.  This will help cool me off while I try to fix my water pump!  Thanks SAM
  • Dalehelman
    There is also a GFCI on the plug for the AC.
    1. Hash  T@B Fun
  • Homebodyatheart
    @PGSUtah just think...you've got your first good campfire story! I did the same thing, no idea the power pole had breaker switches, and ran for two days on battery and propane! The plus side is now I know I can do this without shore power. Glad it was an easy fix!
