T@B 320 Roof Strength?
Barry
Barry Member Posts: 11
I'll be waxing my 320 CS-S for the first time and need to know whether the roof will support my weight while doing so.  Couldn't find the info by searching, and hope I'm not duplicating someone else's effort.  Thanks ... Barry in Belleville.
  • Homebodyatheart
    @Barry we use Meguires Wash and Wax- no duplication of efforts and the Tab looks great afterwards. To answer your question, I don’t believe that the roof can hold a person without damaging the unit.
  • Verna
    Verna Member Posts: 6,876
    The roof support members are 1” square aluminum struts and they cannot support your weight.
    I wax my T@B twice a year and I use a winter snow scraper with a rag wrapped around the scraper end to apply and to wipe off the wax from the roof. You’ll need a 6’ ladder to carefully work from.
  • Dalehelman
    NO
    1. Hash  T@B Fun
  • 4ncar
    4ncar Member Posts: 1,072
    Well...I’ve been on my roof 3 times with no I’ll effect. I weigh 165lbs dripping wet.  I spread my weight across and stayed as close to the edges as possible.  I did have to climb up via the diamond plate tub once while on the side of the highway...fireside story...
    I wouldn't make a practice of it, but I have done it.  Your results may vary...
  • Verna
    A T@G’s roof rack attached to the sidewalls is only rated for 100 lbs. To lay on a T@B’s roof with the same construction, and 12” wider, is taking a great chance for unpredictable results.
  • Barry
    Thank you, everyone, for your prompt and insightful responses.  Discretion  being the better part, I think I'll find another way, as some of you have.  Cheers ... BinB
  • Ratkity
    Ratkity Member Posts: 3,770
    The best way I felt I could reach to the center when putting on the fan cover was to use an 8 ft A-frame ladder on each side.
  • hymie
    hymie Member Posts: 150
    @Barry in Belleville..... Ontario?
    James & Jacquie     Almonte, Ontario
    2016 Jeep Cherokee & 2017 T@B Outback
  • Barry
    Yeah, hymie; sorry I neglected to properly introduce myself.  My info is now posted in the "Introductions" category.  Cheers ... BinB
