400 bathroom door
JonNLeslie
Member Posts: 20
When traveling our bathroom door will not keep closed. It swings wildly around and has gouged our ceiling. Has anyone else had this problem and what was the solution to prevent this? Thanks
Jon and Leslie
MPLS,MN
Jon and Leslie
MPLS,MN
Jon and Leslie Richey
2018 T@B 400. TV 2016 4 Runner
Minneapolis,MN
Do you have the little lock on the door?
There should be a strap at the top to prevent the from swinging into the ceiling. Our door also latches very securely.Happy Trails,
Phil & Anita - Driftless: 2018 T@B 400/2015 Ford Explorer
Make sure the door is not warped. You might have to adjust the latch.BigGrover
2019 T@b 400 Boondock Lite
2018 Ram 1500 Quad Cab Hemi
Central Alabama -
Thank you for the comments. We do not have a lock on the door and we will put a strap on the door. The latch when we leave for a trip is securly shut but 10 minutes later the door is open.
Minneapolis,MN -
Our Bath door does not have a strap. Just the closet door.
2018 T@B 400, 2017 Nissan Titan Crew cab -
@JonNLeslie here is a pic of
our strap Happy Trails,
My 400 also has this strap. Build date Nov 2017.
Utah Driven
2019 T@B 400 (Ex 2018 400)
2015 MB GLK 250 Diesel
2018 GMC Canyon Denali Duramax CCSB
We bought our 400 in August 2017. We are going to the Ucamp and also have some warranty work done. We will add the strap to our list. Thanks
Minneapolis,MN -
I actually had our door replaced because the fit was not great when closed and the latch kept comming loose.2018 Tab 400 towed by 2013 F150
Evanston Wyoming home -
We had the same problem. Easy to see the door is warped. At Ucamp, we'll have this checked. But our dealer adjusted the hinges and and the door doesn't open when we travel anymore.
my door latches well but does come open on rough roads so i lean the cushion from the dinette against it and all is well. I also have the strap.2018 T@B 400, 2015 F150 tow vehicle.
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
