Greetings all, glad to be here!
A little history, my history is tent camping, but I’m finally lining up to camp by travel trailer RV. And I am entranced with the intelligence of design of the 2018 CS-S, especially with the “boondocked” options. I promised my girlfriend I will make her coffee, OUTSIDE, in Any kind of weather!
So, here’s my query: It gets extremely hot in the Texas Hillcountry, ie. Austin, such that within this Memorial Day week, we are expecting 4 days to surpass 100 degrees. I wonder if the T@B CS-S A/C is sufficient for the brutal summers here?
While tent camping, I even built a stand with wheels, to duct-tape in a window unit A/C into my tent! But even so I stopped tent camping past about April, some time ago, cause it didn’t work that well. So, I am sincerely in search of a cooling A/C method while camping, preemptively, in the CS-S, to lower the temps even to 65-70 degrees while it’s 100 outside, if possible.
We rented the T@B 320 in March. Admittedly i may not have activated the circumferential fan right, but it definitely did not cool down very much, and it was only in the 80’s that weekend.
I would appreciate any feedback experience wisdom and science about this issue! Cause it’s a big deal to me; thanks SO much for your help.
0 ·
I always keep the roof fan vent open, without the fan turned on. Then one or both side windows are secured in the first locking position that keeps the window open about an inch. And don’t forget to turn the switch on for the auxiliary A/C Fan.
By keeping the roof vent open, the side window(s) cracked, and the auxiliary fan on, you are helping the natural convection of air to move around the interior, making it feel cooler.
I will add that the former owner upgraded our A/C unit to a newer digitally controlled one with remote control, though I am assuming the BTUs are similar.
2009 Subaru Outback R 3.0
2022 Ford Ranger XLT Super Cab
Thanks for posting the photos. The A/C is made for a typical installation in a window where the vents on the side take in cool air and the rear exhausts the hot. Because the A/C is in an enclosed cabinet, mixing of the two may occur.
We have been accruing information on different RV forms and appliances to be fully knowledgable before taking the plunge.
Thing is here in the Hillcountry only the A/C makes summers livable and unless it has possibility of getting ice-hold we won’t be camping.
So, i am supposing that somehow I must get a regular-sized RV A/C installed on the roof of this structure, even though i hear the T@B roof is not strong enough to hold it up?
Not sure I’m understanding why i can’t install a: 13500 BTU 90 pound A/C in the roof of a CS-S T@B. Then I can select Hi when connected to ShorePower, and Low when/if boon docking.
Here is a link with a photo of a roof mounted A/C. Note the sag.
https://tab-rv.vanillacommunity.com/discussion/248/aftermarket-airconditioner-for-2014-t-b
I think i’m seeing the light! Hope this link above works; the Amazon reviews and descriptions look pretty great and applicable. Like: Remote sensing to the remote control; easily and quickly cools down 150sqft; 48lb etc. This is also answering other questions, that if still not COLD Enough, could Perhaps go to 8000 BTU’s though this should be sufficient, and they do always get heavier and larger.
So, I just need to find out what is the maximum size of A/C can fit into the wall of the CS-S and still work like they designed it to work, ie. to include that exterior fan to improve airflow and cooling! And find the perfect A/C for the slot and capacities.
18.5” (wide) x15.5” (deep) x13.4” (high)
... whereas the Danby trim opening is:
16" (wide) x 11" (high) with depth to front of 15.5"
...so yes the trim that separates the inner and outer cycles would have to be opened up quite a bit. Maybe one of the gurus on the forum who have replaced their A/C already can say whether the main box is big enough for the 18.5x13.4. I haven't taken off the interior trim or measured the external vent to check. Cannot block the side intake vents on the exterior half so supporting box and exterior vent better be at least 20" wide. We loved the picture of the unique sagging roof approach.
Sounds like the 6000 BTU machines will cool down up to 250sqft, very efficiently, and the Friedrich sure looks sweet, if pricey. Although that and the 8000BTU model only cool down from 115degrees F... so shade might be essential. Like a tarp put up over one’s teardrop in severe conditions.
Trips - 48 Mileage - 63,452
