Helper for Diving Behind Back Seat
BrianZBrianZ Member Posts: 1,768
edited November 2019 in Tips & Tricks
I'm guessing I'm not the only one who has bruised ribs from trying to reach over the back seat to get things from the bottom of the back storage areas.
I recently got one of these to help..
https://www.amazon.com/dp/B00V6PW5CY
And I think it helps a lot.
We store water hoses & electric cables, etc, back there, but it's a pain trying to reach things on the bottom.  With this grabber, I was able to easily pick up a water hose or filter and lift it up without having to do "the dive".
What I like about this particular model is that it folds to a quite compact size that stores easily, such as in the passenger side shelf over the window.  It has a peg at the end which is handy for hooking under things like a hose or cable to pull it up, or something too heavy for the gripper part to lift easily.  I was able to use the gripper to pick up a water filter with a bunch of fittings attached. Maybe I could use it to set a tv antenna on top of the trailer (if we're ever in a place where we're close enough to civilization to actually make use of one).
In any case, it definitely makes at least one task less painful.
