UCamp 18 ( single dump valve mod )
Dalehelman
If you are interested in this modification and you are attending UCamp 18. I am bringing enough parts to do 3 of these conversions. Total cost for parts $75. Do it yourself and save. Difficulty level is about a 2 out of 5. I will be available for help and instruction. Contact me ahead of time if interested.
  1. Hash  T@B Fun
    Dale, check for PM.  Thanks
  • dragonsdofly
    @Dalehelman, pm also.
  • Homebodyatheart
    I can vouch for @Dalehelman ‘s work. He reconfigured mine. It works well, and so easy to dump the tanks! Thanks again Dale!
  • cbarnhill
    cbarnhill Member Posts: 330
    I can vouch for his skills as well. Love my single dump mod. I hope you’ll do this at tabazona, too. ;-))
    Cindy with my 2015 MaxS (Puppy) and my 2015 Subaru Outback (Boo)
  • db_cooper
    db_cooper Member Posts: 749
    Dale, does this mod work with the Outback platform?
  • Dalehelman
    @db_cooper
    yes I have done several.
    1. Hash  T@B Fun
  • Dalehelman
    Yes
    1. Hash  T@B Fun
  • Photomom
    Photomom Member Posts: 2,217
    I’d like to see how (if) this works with the front platform. The gray valve is a pain to get to.
  • Dalehelman
    @Photomom
    Those with the Outback platform have been very pleased. I will se if I can find some pictures.
    1. Hash  T@B Fun
  • 4ncar
    4ncar Member Posts: 1,072
    I would think the gray waste gate would need to pivot 90degrees with the platform...
  • Dalehelman
    @4ncar
    It can very slightly from trailer to trailer, but it is always very accessible.
    1. Hash  T@B Fun
  • Photomom
    Dale, I might be interested if it makes it easier to reach the gray valve without having to crawl around on the ground at the dump station.
  • TerryV6
    TerryV6 Member Posts: 1,101
    Does NuCamp offer this as a kit you can order thru Elsie?  I added the platform.  I bought a right angle and straight extension to my existing pipe setup.  I still have the two ports then.  I can see the appeal of a one hook up feature.
    2016 NuCamp 320 T@B Max S
    T@bbey  Road
    Appleton,  WI
  • jgram2
    jgram2 Member Posts: 1,522
    @TerryV6 I’ve been contemplating an extension for our black tank valve under the Outback platform. You’ve no problem with it staying connected while traveling? What’s the right angle for?
  • TerryV6
    These extensions worked okay on our last trip.  The only problem I had was when taking the hose "off" the extension started to thread off too.  I probably will make them permanant if I decide to stay with this..
    T@bbey  Road
    Appleton,  WI
  • TerryV6
    @Photomom
    Hi Dale, Id sure like to see these as well.  Is this just a simple connect, or is there some cutting and relocating of gates involved?
    T@bbey  Road
    Appleton,  WI
  • Dalehelman
    edited June 2018
    @TerryV6
    One cut to the gray water pipe to create a 90*. Everything else is bolt together. Entirely reversible if you ever wanted to. I  guarantee you will not want to.
    1. Hash  T@B Fun
  • TerryV6
    Dale, could you put me down for one of your kits?
    T@bbey  Road
    Appleton,  WI
  • Dalehelman
    edited June 2018
    @TerryV6
    You are #2
    I can collect additional parts if others are interested.
    1. Hash  T@B Fun
  • TerryV6
    Thanks a lots!
    T@bbey  Road
    Appleton,  WI
    Somebody needs to put a hold on your Amazon Prime @TerryV6!  You’ve gone off the deep end🤣
  • TerryV6
    Funny...  don’t you think???
    T@bbey  Road
    Appleton,  WI
  • Dalehelman
    And that rig is just for weekends.
    1. Hash  T@B Fun
  • Photomom
    TerryV6 said:
    Well...  I bought our camper and said to my wife, “Wife, we are now set to do some serious camping...
    Then, we decided to add a few things.  Then, after being on this forum and seeing all the ideas, we decided a few more changes were in order.
    Then Dale started showing us all some new ideas in camper modification.  Now we are definitely set for some serious camping....
    Help me me before I mod again...
    I think that’s a really classy horse trailer.
  • Photomom
    @TerryV6
    You are #2
    Dale, I am interested, assuming it will work with the platform and doesn’t involve a lot of fiddling with the pipes. Will probably need hand holding.
  • Dalehelman
    edited June 2018
    Photomom said:
    @TerryV6
    You are #2
    No fear this modification is completely reversible. I guarantee you won’t want to though. You would be #3. Keep in mind tanks must be empty and dry. The best way is to empty and flush. Then leave both gate valves open and the end caps off overnight or the last 50 miles or so.
    1. Hash  T@B Fun
  • Homebodyatheart
    @TerryV6 actually, the final mod in the pic would be a good start for storing @Dalehelman 's tools and gear! Have you ever seen his set up in the back of his jeep? It's impressive! And that's just his traveling kit! :rofl:  (In his defense, he keeps an impeccably clean and well organized garage.)
