UCamp 18 (power tongue jack conversion mod)
Dalehelman
Member Posts: 2,414
If you carry a cordless drill when you camp, and you would like to convert your tongue jack to power. Come see me. I can hook you up. I will show you how to do it yourself. Or I will do it for you for $10.
- Hash T@B Fun
4
@Dalehelman, we're probably in on that one too!2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
Draco dormiens numquam titilandus.1 -
Dale, why do you have a bucket on your tongue?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio2
Good idea.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
Yes
- Hash T@B Fun
For those of us not able to attend, is there a writeup about this somewhere? My arm is tired from all that cranking...Thanks.Jon WJonW - 2018 T@B 320UMarlborough, Mass0
@JonW Here’s the write up: https://tab-rv.vanillacommunity.com/discussion/1395/power-tongue-jack-cost-less-than-a-buckJohn, Judi, Guinness & OD in PDX
Half inch bolt cut off excess threads drill a 5/32” hole 1/2” from the head. Very important that the hole is straight thru the center. Remove top cover. Drive out roll pin in crank. Remove crank. Insert bolt and drive roll pin in drilled hole. Only use a common grade bolt. Hardened bolts will be to hard to drill and are not necessary.
- Hash T@B Fun
The bucket also catches the drooling folks that see all of his mods!!!
@Dalehelman also helped with this mod...Zipitty-do-da & you can raise & lower in a flash! 2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf2 -
@Dalehelman, I'm not so handy, but I would gladly take you up on your $10 offer. What size socket do I need?Bill & Helen; 2017 T@B S Maxx, (Serenity Now!!); TV 2019 Honda Ridgeline,
Woodstock, Ontario0 -
3/4”
- Hash T@B Fun
Thanks, @Dalehelman - we're at site 33A.Bill & Helen; 2017 T@B S Maxx, (Serenity Now!!); TV 2019 Honda Ridgeline,
We are in 8D
- Hash T@B Fun
I did this mod also, but switched it back to the handle. Decided that a little exercise never hurt anyone.The HobbiT@B, 2015-L, towed by a2014 RAM C/V0
I am just trying to save myself for more important things😜JandJ92010 said:I did this mod also, but switched it back to the handle. Decided that a little exercise never hurt anyone.- Hash T@B Fun
3 -
Hay, @Dalehelman, can you add me to your list as an “almost maybe”? I’ll bring the 3/4” socket. I think that’s all...or did I miss the bolt part? It’s so new....I’ll have to really convince myself it’s necessary....
2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red2
I have the bolts
- Hash T@B Fun
Thank you. @Dalehelman! I’ll let you do the work.
My sister’s dog tripped me this am on gravel, and I’ll be betting the bandaids will still be on my knees and hands next week...OUCH ;(
I have the bolts.👍Verna said:Thank you. @Dalehelman! I’ll let you do the work.
My sister’s dog tripped me this am on gravel, and I’ll be betting the bandaids will still be on my knees and hands next week...OUCH ;(- Hash T@B Fun
I just did the mod on my 2018 Tab 400, great mod and easy with your detailed directions. Thank you2018 T@b 400, 200ah Lithium with Solar
2013 Tundra TRD 5.7L
Massachusetts1 -
Yes I was able to drill the centered hole on the first try. I ground a small flat and center punched it before drilling the hole.2018 T@b 400, 200ah Lithium with Solar
Massachusetts1 -
👍DenisP said:Yes I was able to drill the centered hole on the first try. I ground a small flat and center punched it before drilling the hole.- Hash T@B Fun
Hey @Dalehelman! I absolutely love this mod! I’m in a campground in Indiana and the tongue jack is at the very longest it can be due to the slope of the campsite. Oh, without this mod, it would have taken so much effort to crank it up, but not with your mod. Thank you so much!Verna, Columbus, IN
Towed by a white 2019 Ford F-150 4x4 Supercab, 3.5L V6 Ecoboost “The Truck”3 -
👍Verna said:Hey @Dalehelman! I absolutely love this mod! I’m in a campground in Indiana and the tongue jack is at the very longest it can be due to the slope of the campsite. Oh, without this mod, it would have taken so much effort to crank it up, but not with your mod. Thank you so much!- Hash T@B Fun
2
- 424 Service/Maintenance & Recall Notices
