Moving lagoon table
Papa
Member Posts: 27
Suggestions please: 2018 cs- s; I like to roll my bedding up and under cabinets space, you can’t sit under there anyways,
question what do with lagoon table, the lagoon table be perfect position if it was more in the middle of the seating ,
any mods on how to get it in middle.
@Papa, the Lagun needs a longer arm to extend the table further from the back wall. Not sure if you can mount some kind of projection to extend the bracket mount. We mount the Lagun on the outside passenger side under our tent. Then use a small, portable table from Walmart inside.
You can’t mount the Lagun bracket on the passenger side due to the radiator, except right next to the door. You may be able to mount it on the driver side bench.
“I used a solid piece of oak1x6 to space out to clear the the bed slat cleat. On the back of the panel I screwed a ¾ inch plywood cut to fit within the frame of the panel. I bolted the mount plate with 3" S/S bolts, lock washer and lock nuts. For a table top I used the bed slat that's used with the original table.
Check this out:
https://www.google.com/search?q=Lagun+site:http://tab-rv.vanillaforums.com/&source=lmns&prmd=mvin&hl=en&ved=2ahUKEwiYjuHftorcAhUQa60KHcA8C9AQ_AUoAHoECAAQAg
https://tab-rv.vanillacommunity.com/discussion/3177/modifications-lagun-table-shelving-and-more
This one is the ticket. Look at all her pictures.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
