Newbie question regarding draining the cold and hot water systems
 I am not going to be using my  2016 T@B 320 s for about six weeks so I drained the fresh water tank and the hot and cold water system. I think I found all of the drains (fresh water valve and drain in front of the tire under the door, hot and cold drain valves to the right of the Alde unit with drains directly through the floor emptying under the trailer, and the Alde pressure relief valve next to the Alde and emptying directly through the floor) but one of the manuals I have read says that there is an Alde drain also. I have not found that drain.
Is there a drain from the Alde?
Thanks
2016 T@B 320 S
2018 Honda Ridgeline
North Dakota
    The Alde Safety Relief valve functions as the Alde tank drain.
  • ericnliz
    ericnliz Member Posts: 4,437
    @GDawg, It's the yellow flip valve. Straight up is open. Parallel to the floor is closed.
  • GDawg
    GDawg Member Posts: 34
    Thanks! Trying to figure out what is what and what goes where in these units is rather difficult at time. I appreciate all the help offered on the Forum.
    Thanks
    2016 T@B 320 S
    North Dakota
  • JimEngel
    JimEngel Member Posts: 45
    This covers draining among other issues:
    http://www.angelplace.net/tab/Winterization.pdf
  • GDawg
    Great article/instructions!! Thanks so much.
    2016 T@B 320 S
    North Dakota
    @GDawg, if you haven't found it already, the User Manuals... category has literature for  the Alde, documents on winterizing, and info regardiing myriad other T@B systems.
  • GDawg
    Thanks!
    2016 T@B 320 S
    North Dakota
