Newbie question regarding draining the cold and hot water systems
I am not going to be using my 2016 T@B 320 s for about six weeks so I drained the fresh water tank and the hot and cold water system. I think I found all of the drains (fresh water valve and drain in front of the tire under the door, hot and cold drain valves to the right of the Alde unit with drains directly through the floor emptying under the trailer, and the Alde pressure relief valve next to the Alde and emptying directly through the floor) but one of the manuals I have read says that there is an Alde drain also. I have not found that drain.
Is there a drain from the Alde?
Thanks
2016 T@B 320 S
2018 Honda Ridgeline
North Dakota
The Alde Safety Relief valve functions as the Alde tank drain.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio2
Thanks! Trying to figure out what is what and what goes where in these units is rather difficult at time. I appreciate all the help offered on the Forum.
Thanks
2016 T@B 320 S
North Dakota
This covers draining among other issues:
http://www.angelplace.net/tab/Winterization.pdf2 -
Great article/instructions!! Thanks so much.
2016 T@B 320 S
North Dakota
@GDawg, if you haven't found it already, the User Manuals... category has literature for the Alde, documents on winterizing, and info regardiing myriad other T@B systems.2015 T@B Max S (320)
Thanks!
2016 T@B 320 S
North Dakota
