This has probably been covered, but my search didn’t turn up much. Apologies if this is duplication. I have just completed my first winterizing and am left with the following questions.
1. Opened the yellow drain to the Alde hot water tank but not much came out. How can I tell if it is empty ?
2. Drained the water tank and pumped “coolaid” thru the system using the bypass valve and a Camco bypass kit so there is none in the tank. I tipped the trailer up at the front and adjusted so the drain was lowest at the back and driver side. Is the tank empty and should I be concerned about a small amount (if any) of water left on the bottom of the tank ?
3. Just forward of the water tank drain there is a short black 1/2 “ hose extending down a couple of inches and has a red fitting on it. What is it for ? A vent for the water tank perhaps ?
4. Last query. This morning was cool and damp. There was a film of dew on the outside and on some surfaces on the inside. Presumably, on the inside, it all evaporates as the trailer warms up. To promote warming should the blinds be left open somewhat ? Should the head vent be partially open ?
Thanks for any comments you might have.
400 - 2019
St Catharines, ON
0 ·
