I am winterizing my camper and cannot find a picture online that looks like mine attached here. Can anyone shed some light on which are the drain valves? Thanks!
I noted that too. I suspect it is a valve to disconnect the CW supply to the Alde.TabberJohn said:...
No Alde bypass loop with cold water drain but there appears to be a shut-off valve for the cold water feed in the lower left.
Ahhh. I thought that valve looked a little peculiar in the photo--not a quarter turn valve as I stated above, but a tee-handle. Thanks for the clarification!ChanW said:The 'dead center' white tee-handle hot water drain is the same as ours. You lift it up about a quarter inch to get it draining. There's another for the cold on ours, but it looks like the yellow valve is your cold drain....
