Leaving sewer hose adapter(s) in place while driving
duckblind123
Member Posts: 68
I wanted to ask if anyone has left a sewer hose adapter(s) (90 or 45 degree) in place while driving. I have a T@B 2016 Max S with the aluminum platform installed. I did not modify the standard black and grey water dump valves. Since the platform makes it difficult to access the dump valves, I purchased a 45 degree for the grey and a 90 degree for the black, which make it much easier when dumping. However, I wanted to know if anyone has left these adapters attached to the black and grey valves while driving. The black and grey valves would be closed and you can put a cap on each adapter, but is there any issue with leave them on while driving?
Interested in all comments.
2016 T@B S Max (H@banero) - 2025 GMC Canyon Denali - Magnolia, TX
I added the same extensions to my gray/black tank valves and I leave them on all the time. There were several discussions on these a couple of years ago and several other owners stated they leave them on all the time.
I also leave mine in place all of the time. Never has been an issue.
Thanks for the comments. I was hoping to leave them in place.
Marc & Janet
2016 T@B S Max (H@banero) - 2025 GMC Canyon Denali - Magnolia, TX0 -
I did this on my Casita trailer and it should work great on any trailer. The plastic mounts fit the hose diameter great. On the outbacks with higher ground clearance I see no problem. It sure beats storing the stinky slinky in the refrigerator! Art see
www.casitaclub.com/forums/topic/469-photo-permanet-mount-for-sewer-solution/2019 TaB 320 S Boondock Edge0 -
Are you all talking about elbow extensions as per the OP, or the straight extensions I’ve seen discussed in other threads?John, Judi, Guinness & OD in PDX
Before I combined the black and grey outlet, I had an extension on the gray outlet. I used a large ziptie connected to the outback platform to secure and keep from drooping a bit.2015 Max S Outback | 2010 Xterra -- Retired
Yes, I was asking about the elbow extensions for the sewer hose connections.
Marc & Janet
