I've scanned the forum but didn't find the answer. I'm in the planning stages of my flexible solar install on my 320 Boondock. I've done multiple solar installs on my and friends boats. So solar is not new to me. Just the particulars of T@b installs are.
How are the cables run from panel on roof? Are they tucked under the plastic trim? I assume 3M VHB is used to attach panels. Any recommendations best place to mount controller?
Thanks.
Odessa, Fl.
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
Greg & Marlene (Tucson, AZ)
This makes an extremely clean install, but is going to require puncturing the roof skin.
Odessa, Fl.
Adventure Canadian Style
2018 Tab320s Boondock Edition, 2018 Toyota Forerunner TRD
I put the panels in series to reduce the amount of cabling required, so the panels come in at 24 V and the MPPT controller reduces it to whatever is needed to charge the batteries. I’ve seen up to 20 A of charging, typically 10 to 15A normally.
Poughquag, NY
