Water comes out drain tube when going off water heater bypass
I am dewinterizing my 2019 400.  I have city water hooked up currently.  When I switch the hot water heater from bypass to RV I can hear the tank filling and then when it is full it will start spilling water out the drain tube on the underside.  When I switch it back to bypass it will stop in a moment.  Not sure what is wrong.  Any ideas?  Going camping tomorrow and would like to get this working.  Thanks
2023 F-150 Powerboost hybrid
2019 T@B 400 Boondock
  • Dutch061
    Dutch061 Member Posts: 765
    By chance are the Alde drain valves open?
    2020 400 BDL aka "Boonie"
    Concord, NC
  • grubbster
    grubbster Member Posts: 115
    If you mean the yellow lever valves, yes they are closed.
    There are several drain tubes. Can you identify  exactly which one the water is spilling from?
  • grubbster
    Clear plastic tube under the Alde just inside the frame.
    Are these closed?
  • grubbster
    Yes
    I don't have a 400 so I'm still not clear which tube you are referring too. Can you determine what is on the other side of the leaking tube, on the inside of the service compartment? Where does that clear plastic tube lead to on the upper end?
    If you can provide one, a picture would be helpful as well.
  • cottonmouth
    cottonmouth Member Posts: 109
    If this is how the valves are currently set, that is the open position I believe.
    2021 T@B 400 BDL aka Little Joe
    2019 Tundra Crewmax aka Hoss
    SE Louisiana
    Yellow lever down means the drain is closed. The line itself remains open for water to flow.
