Refilling fresh water tank in T@B 320 from a water jug
I especially like the shutoff valve on the hose attachment. Made mine with stuff I had at home after struggling to fill the tank. Reinventing the wheel seem to be my specialty. Running back to the faucet after the tank is full is not good.Thanks. Love this forum and its helpful members.
I've been thinking about this myself because the last Sani-station I was at didn't have a proper hose end that I could screw into the Tab, just a cut-off hose. With my 2021 tab 320, could you fill the tank from a container of water using the pump the same way you fill the lines with anti freeze using the sanitation connection?2021 Tab320S Boondock, 2019 Subaru Outback 2.50
Yes @SusanD. Use the same settings that you use to siphon water into your tank to sanitize.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Thanks @Sharon_is_SAM! I was a little nervous but I'm going for it now.2021 Tab320S Boondock, 2019 Subaru Outback 2.50
