Black Rubber Screw Cover for Sink
We have '18 T@b 400.  One of the rubber screw covers from the sink has gone missing.  I would like to replace it because the glass top rests on them.
The part number is:  Dometic SMEV 44990000127 OEM Screw Covers.
I found them for sale at the low price of of $35 for a pack of eight.
Does anyone know of a cheaper price?
Or maybe you would co-sign a loan to cover this cost.  I know I am being cheap, but I feel like I should get a thousand rubber nubs for $35 instead of eight.
Thanks,
Bill
2018 T@b 400  towed by a 2012 JKU
  • falcon1970
    falcon1970 Member Posts: 758
    I you have a mouse pad you can sacrifice you can fabricate feet from that.  I have used mouse pads for many different projects.
    Denny16 Member Posts: 5,430
    edited June 2020
    If you do not need 8 of them, find several TaB 400 owners to share the cost.
    Check out Etrailer screw covers.
  • Tampakayaker
    Could you make a dot out of black silicone sealant?
    Tampa FL
  • Michigan_Mike
    Check your local hardware store as that’s where I found them for my former 320 T@B.  👍🏻
  • Marceline
    Marceline Member Posts: 1,777
    Maybe a job for Sugru?
    https://sugru.com/
  • Tampakayaker
    https://sugru.com/
    Stuff is great but once you open the packet be prepared to use all of it.  Resealing doesn't seem to keep it from hardening.
    Tampa FL
    pthomas745 Administrator, Moderator Posts: 4,685
    I stopped buying Sugru since it was so wasteful.  There are millions of different screw head covers available, it would seem if we could figure out the exact screw size we could find one easily.
  • jimcenname
    jimcenname Member Posts: 348
    edited October 2020
    In addition to screw covers falling off, the screws underneath are rusting. Anybody replace the screws with an alternative?
    2019 T@B400
    Southern California
    Full-timer since 2019
  • Verna
    Verna Member Posts: 6,876
    A nüCamp dealer said he just uses a dab of silicone caulk for the bumpers.
    For a screw, @jimcenname, get a stainless steel screw from Lowe’s or your local hardware store. I only had one screw that kept rusting and it was the one I couldn’t keep a bumper on.
  • ChrisFix
    ChrisFix Member Posts: 743
    @jimcenname
    My 2021 has the same looking rust on just one of the sink screws...
    But I believe it is the collar that the screw holds down that is rusting...not the screw itself.
    That should be a dometic part, and I plan on contacting them about it when I get a chance.
    The screw in your picture looks fine, but the collar is all rust like mine is.
  • tepe50
    tepe50 Member Posts: 37
    By 2020 400 is also doing the same thing just the other day actually
    2020 tab 400 BDL & 2013 siver shadow 5x10
  • Docbadger1
    Docbadger1 Member Posts: 15
    I too ran into this issue (2021 Tab 400) and decided to use my 3D printing skills to print a replacement. You can find my file here if you want to print your own. https://www.printables.com/model/844027-screw-cover-plug-for-rv-sink  The printed replacement works fine. The first test print was in red TPU and will print more in black TPU so I have them on hand.
