2020 320-S Boondock...jack to bring
trimtab
trimtab Member Posts: 237
Our trailer is parked on some uneven ground, so I am wondering if anyone knows the inches from the ground to the frame, close to the wheel. Wondering what jack I should use just in case.  ( did a search, could't find the answer ) thanks
2020 320-S boondock, solar, 2020 Honda Ridgeline RTL-E
  • trimtab
    O..tire size is 235/75r/15
    I've always assumed the standard scissors jack that came with my truck would work. It collapses pretty flat for storage. But, I confess I haven't actually tested it.
    At home I still use the (no longer recommended) tongue-jack-and-rear-stabilizers method to raise the wheels. However, if I were trying to change a tire on the side of the road, I'd prefer an option that doesn't require unhitching the trailer.
  • GatorEgg
    GatorEgg Member Posts: 482
    The factory jack which came with my 03 and 19 Toyota Tacoma’s worked fine under my 2018 320 Boondock.
    Odessa, Fl.
  • CrabTab
    CrabTab Member Posts: 457
    We carry this 4 Ton bottle jack. It has 15" of lift and is easy enough to operate at the jacking point. It worked well on our Boondock with the same size tires when we last serviced bearings, brakes and did a tire rotation in the driveway.
    https://www.harborfreight.com/4-ton-hydraulic-heavy-duty-bottle-jack-69472.html?_br_psugg_q=bottle+jack
    2019 320 Boondock Edge
     - Sold Jan 2022
  • DougH
    DougH Member Posts: 1,110
    @trimtab ; 6-5/8" on mine (ground to bottom of L-bracket lift point).
  • trimtab
    Thanks DougH, that is what I needed.
  • mntrails
    mntrails Member Posts: 144
    Mine measures 11-3/4" - (2021 320 S) - tape body is 3-1/8"
    2021 T@B 320S Boondock - 2018 Toyota 4Runner
  • DougH
    @mntrails @trimtab ; Wow, the latest Boondock is 4-5" higher than the older non-Boondock.  Must be nice on dirt roads and in snow!
  • trimtab
    So jacking up the trailer is one thing, but how far does the actual wheel drop, because of the swing arm suspension? It it drops 4", then I would need a jack that would go up aprox 16"?
  • mntrails
    @trimtab, I haven't jacked the T@B up yet so unfortunately I don't know.  If you use a scissors or bottle jack though, you're probably traveling with several nice long blocks of wood or the lego blocks for leveling that you could use under the jack.  That's probably a good idea regardless to get a nice firm base.  Offhand though, I would agree with your 4" estimate - seems in the ballpark to me. Good luck!
  • trimtab
    Have a smaller than usual 2 ton floor jack.  It lifts to 15". My whole point was I did'nt want  to buy another jack..looks like some 2 x 6  lengths are going traveling too, o well. Trying to travel light is tough.
