Prodigy RF brake controller inoperable - Resolved
lino
lino Member Posts: 246
I am posting this in case it helps someone else later.
I have a 2017 T@B Q and last week the Prodigy wireless brake controller would not connect to the brakes but was paired to the Blue Tooth
Just needed to replace the power fuse in my car that is for the 7 way pin And it connects right away
(Title edited for search purposes.)
  • mreric
    mreric Member Posts: 154
    edited July 2020
    the prodigy controller uses RF signal.   what do you mean by bluetooth?
    your 7pin connector would need to have power running to it for it to work.    so if there was no power coming out from it then the controller cannot receive power.
    @lino - thanks for this.  We don’t consider the fuse on the charge line for the 7 pin.  What did you see on the hand-held device to give you a clue that it was not working?
  • lino
    The Prodigy controller device had the “n.c” error message because the brake line did not have power from my 7 pin on the tow vehicle
    The prodigy controller I believe but could be mistaken links to the trailer brake via Bluetooth to control the actual brakes once it has power
    Thanks - n.c. - not connected.
    The controller connects to the brake module via radio frequency, not Bluetooth.
    Denny16 Member Posts: 5,430
    Yes, it does use radio, not Bluetooth, which this and along with a dedicated I. TV wireless ( radio) controller is the advantage over the Kurt Exho, which is Bluetooth controlled via a smart phone app.
  • MichiganSunshine
    MichiganSunshine Member Posts: 19
    I can't get my Prodigy RF Wireless Brake Controller to pair.  It's suppose to show 00 after you brake and mine doesn't.  I just got the 7 pin installed and brake lights and turn signals work fine on the TV and trailer.
    Kathy - Lansing, MI
    2017 T@B 320 SC-S, 2016 Suburu Outback
    edited August 2020
    Do you have the 12VDC charging line/pin working?  The Prodigy Wireless uses this connection for power.
    @MichiganSunshine - are you sure a charge wire was installed as part of the 7 pin?
  • MichiganSunshine
    edited August 2020
    I'm not sure.  The added a ground wire and then a converter.  Maybe not because it didn't seem like my battery charged up either after towing.  (note:  I've only been on one trip and I'm a newbie)
    Kathy - Lansing, MI
    Easy test for a charge wire:
    Turn off your battery switch and plug in the tow vehicle to the TaB.  Crank the engine. Turn on a light in your T@B.  If the light comes on you have a charge line.
    Nice, simple way to test the connection.
  • MichiganSunshine
    You guys were correct about the charging wire!
    i have an appointment to have it installed tomorrow.  Thanks for your help!
    Kathy - Lansing, MI
    Ask for 10 gauge wire!
