2020 T@B 320 CSS BDL - warm water when first turn on faucet, then cold
New unit purchased in June 2020.  This is my 2nd Alde unit.  I had one in my 2014 T@B with the analog control panel and no mixing valve.  I am camping where I am just wanting hot water, but did use heat one night in the past week.  Alde is functional, but not consistently producing hot water.  When I first turn on the clam faucet, water is warm, but then turned cold.  I couldn't get any hot water in the shoilet, yesterday.  I have not adjusted the mixing valve, but haven't felt the need during previous trips.  Ideas?  I've gone through the manual a few times and nothing jumps out at me.  Thanks!
Beth
Minnesota
Practicing to be a wanderer
2020 T@B 320 CSS Boondock Lite
2014 T@B 320 CSS M@xx
2020 Jeep Wrangler Unlimited 8 speed automatic
2020 Jeep Grand Cherokee Limited V8
2018 Jeep Wrangler Unlimited Rubicon 6 speed manual
    If you release water using the yellow flapper valve is it hot?  If so, check the Alde Bypass valve.  It should be closed.
  • ontheroad
    ontheroad Member Posts: 489
    @Sharon_is_SAM.. didn't someone recently post that they had flipped the yellow flapper past the open position?
    Former 2017 T@G Max XL
    2021 T@B Boondock CS-S
    2018 Nissan Pathfinder
    Ontario, Canada
    Denny16 Member Posts: 5,430
    Yes, sounds like the bypass valve got closed.  Set the Alde panel to Shower mode to get just hot water.  This resets after. 30-minutes, so needs to be set when you need extra hot water every time.
  • Tundra57
    Tundra57 Member Posts: 640
    Did uou day you setup the mixing valve?
  • twocutes
    twocutes Member Posts: 202
    Hey all-you are awesome! It was the bypass valve.  I suspected it was something like that.  I did not have one of those in my 2014, either.  I was rearranging the clam galley and I must have moved it out of position.  Everything is right with the T@B world now.😀
    Beth
    Minnesota
  • twocutes
    @Tundra57
    I did not adjust the mixing valve.  It’s actually good where it is for summer.
    Beth
    Minnesota
  • Tundra57
    But the hit water is not working, so how can you be sure?
    When i first had my 2019 tab 400, the water would start hot then be cold very quickly. After adjusting the mixing valve all was well. Just a thought.
  • twocutes
    @Tundra57
    Once I repositioned the bypass valve, I had hot water at both faucets.  It's been so hot in Minnesota, that warm is good enough for me right now.  :)
    Beth
    Minnesota
  • Tundra57
    Ok good.
