I know this subject has been covered in many posts, I’ve looked through many of them but most talk about odor when flushing the toilet or odors coming from the gray tank due to dry p-traps.
I follow the protocol of making sure there is water in the toilet bowl and in the p-traps and the dump valves are closed, I dump the tanks every day and flush the black tank after each dump but yet I have a strong odor in the bathroom.
Some background: I have been work camping for over 2 months, I do not have an A/C so on a hot days I turn on the exhaust fan (I have a 320 with fantastic fan) before leaving for work, this is when I would find strong odor in the bathroom when I return. The fact that having the exhaust fan on resulted in the odor in the bathroom was baffling at first but that led me to believe that maybe the odor is coming from around the seal on which the toilet sits. I did some simple tests to prove this and have come to the conclusion that this is the case.
So not knowing much about plumbing in the T@B, my question is: is the toilet mounted on a seal as you would have in a household toilet? What is involved in removing the toilet and re-applying the seal?
2017 T@B 320S 2019 Jeep Cherokee - Southern Connecticut
if not, the fan is trying to find some makeup air to replace what is being forced out, creating a pressure difference between the cabin and the tank, and you are pulling vapors out of the tank through the toilet and sink drains, even with water in them, gas can bubble up and out.
2018 320S Outback
Next, don't dump until almost full and make sure that your ratio of water is at least 1/4 water to waste.
