Tab 400 2021 speakers
rhyno
Member Posts: 393
The Jensen JWM20 cube is a 2 zone system. Could a current 2021 owner please confirm the following?
1. There are two speakers in the front cubbie area over the dinette
2. There are two speakers in the bed area
3. There is no speaker over the kitchen sink anymore
4. Are the front and back speaker pairs wired separately to each zone or do all speakers play all the time on zone one?
I can answer rheee out of the four.
1. Their are two speakers in the front dinette in the left and right overhead cubbies, same as on previous models. This set is normally Zone 1.2. Their are two speakers in the back area, one above the head of The bed on the wardrobe/ wall facing back (same location as before). This previously was its own zone, #3.
3. The fourth speaker is under the galley shelf over the foot of the bed, facing down. This was moved from its previous position over the galley counter center area. This was Zone #2.
4. Zone 1 probably remains the front speakers. As for the other two, I can not confirm they are now paired in Zone #2, or remain individually zoned. A 2021 TaB400 owner with the new Jensen Cube will need to verify this.
That said, I like the change of the galley speaker to the rear area, puts the TV audio back by the TV, which makes more sense to me. Here are a couple of shots showing these speakers
Bed area speaker, top black circle is the speaker, lower one is the AC vent.
Rear Galley/Bed area speaker under the shelf, over the TV, facing down.
The speaker selection on the 2021 Jensen Cube are labeled Zone A and Zone B.
Zone A is the front. Zone B is the back.
The two zones are able to be turned on or off independently (just press the Zone button).
Both on, only one on, or none on (not sure when you'd use that).2025 T@B 400 Boondock Black Canyon with 400Ah Battle Born and Victron Multiplus 3000
2025 Honda Ridgeline Black Edition with Redarc Trailer Brake Controller1 -
@rhyno
For what it is...I'd give it a definite thumbs up. Speakers must be very efficient, because it will get loud without noticeable distortion. I've found it quite enjoyable...In fact I'm listening to Songs From The Wood played via an Amazon Echo connected to the Jensen via bluetooth at our campground in the Blue Ridge mountains as I write this. And for all the sound compromises that entails, it still sounds pretty darn nice.2025 T@B 400 Boondock Black Canyon with 400Ah Battle Born and Victron Multiplus 3000
2025 Honda Ridgeline Black Edition with Redarc Trailer Brake Controller0
