Ram 1500 Class III Bumper Hitch
mandt
We are looking at purchasing a Ram 1500. It comes with a class III bumper hitch. Is that suitable with a 400'?
VIN: 1C6SRFBT4LN419766
Mickey & Terri
2016 Max S
Kalamazoo Michigan
2016 Max S
Kalamazoo Michigan
For a T@G perhaps, for TaB, or other 19-foot trailer, I would go with a class IV receiver type hitch.
I I believe the OP may be confused. Your truck is capable of towing a Tab. A bumper hitch will not be suitable. A Class 3 box hitch, properly installed onto said truck will be suitable.TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback0 -
Yes, the truck can handle a TaB, but I would not trust a bumper mounted hitch. A class 3 receiver on a 1/2 ton truck that is a frame mounted receiver type unit would be ok. Class 3 hitches and class 4 hitches both have 2" x 2" receiver tubes. Class 3 is different in that class 3 hitch weight ratings are consistently lower than class 4 hitches. This makes class 3 hitches much more versatile in terms of vehicle applications. They are found on everything from crossovers to pickup trucks.cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.0
My 2006 Ram has a hitch that is connected to the frame from the factory. If you look below the bumper you will see that its attached to a tube and not just the bumper.
My 2002 RAM had a flat spot on the bumper that I bolted a receiver to. I used it to tow a small PUP without any issues.
You could probably take it to a U-Haul and see if they can look at it and advise you if it's sturdy enough.2006 RAM 1500 4 door, 2016 T@B 320 MAX S
Tampa FL0 -
Class 4 is overkill for these Tabs is all I am saying and that a proper Class 3 box high is sufficient.TV- '16 Chevy Colorado LT Crew Cab-DuraMax
Yes, and I agree, if given the choice. The only difference in a frame mounted setup is the max weight rating.Cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.0
If you have to get a receiver hitch installed, and there's a Class IV option for the Ram 1500 (I think there should be), I'd go with that. Yes, a Class III is enough, but you might want to tow something bigger than a Tab 400 someday.
2019 Tab 400 Boondock Lite
2017 Dodge Durango AWD with Tow Package IV
A can of Skyline Chili in the pantry0 -
Yes, a Ram 1500 has a Class IV hitch option, and is the normal receiver type hitch installed on a 1500, I would think...
- 144 Events & News
- 415 Service/Maintenance & Recall Notices
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
