Leveling Question
runaway30
Member Posts: 86
When leveling blocks are needed under a tire are they also used under the stabilizer?
Depends on the situation. I use a single block under our trailer’s stabilization jadks, as we have a Boondock axle on our TaB400, and the extra added bit helps.
I have a 4 pack of leveling pads that I have never used.
If you want to make your life mush less stressful, get one of these for the low side and forget the blocks.
https://www.amazon.com/Andersen-Hitches-3604-Camper-Leveler/dp/B001GC2LVM/ref=sr_1_32?crid=JZHZQSVWK7IX&dchild=1&keywords=anderson+levelers&qid=1605008741&sprefix=anderso%2Caps%2C174&sr=8-32
If you want to make it even easier, get one of these to determine when it is level.
https://www.amazon.com/LogicBlue-Technology-LevelMatePRO-Wireless-Leveling/dp/B01FGGSWPW/ref=sr_1_1_sspa?crid=266F2S6MDCRR0&dchild=1&keywords=levelmatepro&qid=1605008832&sprefix=levelma%2Caps%2C228&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyQUNOUE9TS1dHUTdJJmVuY3J5cHRlZElkPUEwODMxMTMzQ0hHTUxQR0M4TDkwJmVuY3J5cHRlZEFkSWQ9QTEwNDI0ODhEWlhBMU8ySVlMQVcmd2lkZ2V0TmFtZT1zcF9hdGYmYWN0aW9uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
The price has dropped sine I bought one, but that is fairly normal for me.
These 2 things make leveling and set up so much easier. I can be done before others even get the TV unhooked from their camper.
Brad
2020 400 BDL aka "Boonie"
Concord, NC -
@runaway30: use the leveling blocks under the wheels to level. Once level, you may want(need) to use the blocks under the stabilizers due to muddy /less stable ground or because you need the additional height due to unlevel surface or the boondock axle.TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback -
Makes sense, Brad that leveling device seems like a great way to go, especially if you are solo.
How many leveling blocks do people tend to carry for a 400 boondock I wonder? -
@runaway30
Although I have the 4 pack of leveling pads, I don't carry any leveling blocks for our 400 BDL, to this point I have never needed anything additional to reach either. Granted, it was a weird year for camping but we camp mostly without hookups and mostly via "Hipcamp" in sparse areas which suits us perfectly.
Brad2020 400 BDL aka "Boonie"
Concord, NC -
I use a Bal leveler for the side to side. I use the lego blocks under the stabilizer if the ground is soft to spread the weight around2006 RAM 1500 4 door, 2016 T@B 320 MAX S
Tampa FL -
We use these for our T@B works well enough for us and we have blocks for the stabilizers if needed.
https://www.amazon.com/gp/product/B0838KJYS3/ref=ppx_yo_dt_b_asin_title_o04_s01?ie=UTF8&psc=1
Kristen and Bryan
2022 Nissan Frontier 4D 4x4. 2005 T@b T2
Powhatan, Virginia (Just west of Richmond)
2 Canine traveling companions - Luke and Solomon
- 917 Introductions
- 404 Service/Maintenance & Recall Notices
