OK to use Alde on electric only when covered?
Hi All,
My wife and I finally found our trailer, a 2017 T@B Q MAX, with air conditioner removed and converted to loo storage. Purchased it from neighbors who used it frequently and were meticulous in it’s care.   My unit is covered for winter and I wondered if on electric only I could run the Alde with the cover on (classic accessory, teardrop cover).  There is no combustion, I would think, so no intake or exhaust?  I have tried to find something on this in the search, but nothing came up that answered this question.  Please excuse my naïveté.
BTW:  Mods coming: RVLOCK for door, 2” mattress pad with Sherpa cover, adding Reese Sway Bar.  Have Proven Lock, water pressure regulator, 30 A surge protector, spare on front, #27 battery, cover (as mentioned), radial tires, Camco (Anderson style) balancer, chocks, front wheel.  We live in Wisconsin, so air conditioner would rarely be used but if we begin to travel in the hotter regions, the cabinet can readily be returned to accommodate a unit.  However, we hope to mostly camp off of shore power, but we will see.
2017 T@B 320 Q Max
2018 Toyota Highlander, XLE
Wisconsin
    You are correct that there is no combustion, intake, or exhaust when using the Alde on electric. I am not aware of any reason why running the Alde on electric only with the camper covered would pose any problem, but I'm not sure why you would want to do so.
  • TNOutback
    TNOutback Member Posts: 633
    Would be a lot cheaper to winterize the plumbing than to run the Alde on electric.
  • MadCityJack
    MadCityJack Member Posts: 110
    Thank you.  I want the option of going inside to hang out during the frigid winters here in Wisconsin.  Just getting it to 40 would help.  I could also use a small ceramic heater, but just wanted options.  The trailer has been winterized.
    2017 T@B 320 Q Max
    Wisconsin
    Denny16 Member Posts: 5,430
    The Alde was not designed for continuous operation from what I understand.  Patrick of Traveling with Delany did this with his TaB400 the first winter he had it, and had a Alde issue afterwards, nüCamp indicated the Alde was not desktop run all winter long in freezing conditions.  I use a small ceramic heater to keep the humidity and chill down in our TaB400, it uses less electricity than the Alde running in 1KW mode.
  • Mellow_Yellow
    Mellow_Yellow Member Posts: 357
    Congratulations! What color?
  • ChanW
    ChanW Member Posts: 3,171
    We use ours all the time in the 'off' season, covered or not!
    It will warm up in an hour or so, I'd think, unless it's one of those famous Wisconsin 'cold snaps'! ie: below zero might take longer!
    Perfectly understandable!
    Chan - near Buffalo NY
    2014 S Maxx (ie: "320")
  • MadCityJack
    edited December 2020
    It is winterized but I wanted the option to sit or work on something inside on occasion and temps here will be very cold.  As mentioned above, a small ceramic heater would also work.
    2017 T@B 320 Q Max
    Wisconsin
  • MadCityJack
    Silver with black trim.
    2017 T@B 320 Q Max
    Wisconsin
