Couldn’t find my problem using search(at least not using a tablet). Thought I had the 3010 figured out. We have the digital touch screen. Used the heat the first night camping using shore power. Set temp to 78, power on 2, pump on 3 and continuous. In the morning I turned the Alde off....no green light in the button. Last night didn’t turn the Alde on, but in the middle of the night I guess the temps dropped and the Alde was running. Got up and the green light is definitely off. Is the Alde possessed,broken, or operator error?
Tampa FL
0 ·
2018 320S Outback
Tampa FL
Tampa FL
C = B (just different elements)
What Sharon said. Your assessment would be true in a European Alde, where the higher line voltage allows the use of two different sized heating elements. Doesn't apply here in North America.
