T@B brake light replacement
Babs
Member Posts: 28
Hi,
My 2018 tab brake light needs replacing. Would anyone have the part number, manufacturer’s contact info, and an alternative place to buy one? What is listed on the light is SAE-Stil-93-DOT with a number “2” in the D. Your help is appreciated.
I think you need to replace the entire light assembly, no replacement bulbs are possible. LEDs are sealed in the light unit. You can order a new one through your nüCamp dealer (or any nüCamp dealer). The SAE number is a DoT specification showing the light meets road use requirements, and is not a part number. If you do not want to order one through a dealer, you might try contacting nüCamp to get the part number, and look for a third party source. Personally, not worth the effort for a few bucks, just order a replacement light.
che
2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast. -
@Babs, here are a couple discussion threads that may be of interest to you:
https://tab-rv.vanillacommunity.com/discussion/9639/taillight#latest
https://tab-rv.vanillacommunity.com/discussion/19/led-tail-lights-for-the-t-b#latest
2019 T@B 320 S Boondock Lite; 2025 Toyota Tundra CrewMax 4x4
Greg & Marlene (Tucson, AZ) -
Bayliss, thank you! With your help above, a solution might be in hand.
This is an exact match for my 2018 tab 400. Even came with the silver trim pieces.Babs said:Hi,
https://www.amazon.com/United-Pacific-Surface-Lights-Chrome/dp/B004NYKC70
2018 T@B 400 -
Nice find, good match. Thanks for sharing.
- 915 Tips & Tricks
