Where can I find the mixing Valve??
MerileeK
Member Posts: 1
In our New 2021 Tab 400 We are only getting hot water for 10 seconds at a time.... I see the answer for that is to adjust the mixing valve for the alde system. For the life of me I CANNOT FIND WHERE THE MIXING VALVE IS LOCATED IN MY TRAILER!!!!" anyone???
Under the bed over on the driver side near your plumbing and Alde.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
This is what you are looking for, it has a red knob on top (not shown), remove the top and use it to adjust the valve under it:
On the 2021 TaB400, you have to unscrew the plywood bottom under the drivers (left) side of the bunk, this is also where the Alde hot water tank drain/overflow valve is (yellow handle).
cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.
- 919 Introductions
- 405 Service/Maintenance & Recall Notices
