Tall clamshell, short wife...
gophergrad
Member Posts: 115
I thought I saw someone's idea for aiding a vertically challenged spouse to close the clamshell, but search is failing me. Any clever / artistic ideas, before I just braid some paracord? Thanks!
2017 CS-S Max (Silver & Yellow), TV 2019 Ram 1500
Camping under the Big Sky
Short step or install a flush mounted handle on the inside of the hatch that drops open when the hatch opens.
Here’s how I close the shell on my pickup. This has lasted 2 years and will probably last 5 or 6 more. I put the carabiner on the end so it will swing out to me. This should work on the inside of your latch handle, just be sure to swing it back inside so it doesn’t drag on the ground.(I don’t expect you guys to use an IU one, but it works for me! )
Towed by a white 2019 Ford F-150 4x4 Supercab, 3.5L V6 Ecoboost “The Truck”3 -
That's great. Simple. Easy. Thank you! Pretty sure she has a Lady Vols lanyard around here.....2017 CS-S Max (Silver & Yellow), TV 2019 Ram 1500
Camping under the Big Sky1 -
Virginia Tech lanyards work best ;-)
Go Hokies!
Cheers,
C2021 T@B 400 Boondock 'Valhalla'
2018 Jeep Grand Cherokee Trailhawk V6
veni, vidi, bibi capulus2 -
Go IU!Verna, Columbus, IN
Towed by a white 2019 Ford F-150 4x4 Supercab, 3.5L V6 Ecoboost “The Truck”1
