Tall clamshell, short wife...
I thought I saw someone's idea for aiding a vertically challenged spouse to close the clamshell, but search is failing me.  Any clever / artistic ideas, before I just braid some paracord?  Thanks!
2017 CS-S Max (Silver & Yellow), TV 2019 Ram 1500
Camping under the Big Sky
    Sharon_is_SAM Posts: 10,035
    Short step or install a flush mounted handle on the inside of the hatch that drops open when the hatch opens.
  • Verna
    Verna Posts: 6,876
    Here’s how I close the shell on my pickup. This has lasted 2 years and will probably last 5 or 6 more.  I put the carabiner on the end so it will swing out to me. This should work on the inside of your latch handle, just be sure to swing it back inside so it doesn’t drag on the ground.
    (I don’t expect you guys to use an IU one, but it works for me! )
  • gophergrad
    gophergrad Posts: 115
    That's great. Simple. Easy. Thank you!  Pretty sure she has a Lady Vols lanyard around here.....
  • CJax
    CJax Posts: 62
    Virginia Tech lanyards work best  ;-)
    Go Hokies!
    Cheers,
    C
    2021 T@B 400 Boondock 'Valhalla'
    2018 Jeep Grand Cherokee Trailhawk V6
    veni, vidi, bibi capulus
  • Verna
    Verna Posts: 6,876
    Go IU!
