Hi T@B Nation:
Continuing saga of battery gremlin chasing enters a new and stoopid phase.
Reconnecting Interstate SRM-24 battery (OEM from 2017 perhaps?) and OF COURSE I didn't take a picture of the wires connected to the battery.
One red, one green (red goes to fuse holder, green comes out) and two white leads. Pretty sure the two whites are NEGATIVE, but want to make sure before connecting.
Very likely this SRM-24 battery is dead anyway - failed a test at the Interstate dealer - just want to get this right in my head, since battery issues seem to cause a fair amount of problems in T@B world.
Contemplating an SRM-27 as a replacement, just hooking the old 24 up to check fuses etc. in trailer once shore power is connected.
TIA,
Mike Mc
Make sure you put the main negative cable on last.
With the negative lead of the battery disconnected there is no circuit to cause an arc.
If the positive lead is being disconnected first and the wrench makes contact with any grounded surface -
all the amps in the battery are available to weld your wrench and burn body parts and arc flash your eyes.
Don't be that guy!
Also, turning off the battery cutoff switch does not disconnect the negative wire from the battery.
This should be the first lesson in Electricity/Batteries 101
Sorry for the rant.
RV: 2018 T@B 320S, >100 mods
If you are talking about battery terminals, the negative cable should be the first to leave the battery when disconnecting, and the last to arrive at the battery when reconnecting.
As @tybladesmith implied, mucking about with the positive terminal while the negative terminal is still connected may result in an impressive fireworks display and a prompt change of underwear.
You can learn it here, or you can learn it the hard way! ;-)
Lesson learned: Take a picture of the wiring before messing with it.
Another Lesson I learned: Before you leave the lot with your new camper, take a video of the walk-through. It goes really fast and you think you got it all (meh, I didn't ).
