Are there any special safety precautions or otherwise that need to be addressed when removing the battery for winter especially if the factory solar is installed?
I believe the solar charge from the Victron is active even when the battery disconnect is on.
Should I do anything to the Victron controller?
TIA
0 ·
If you have an inverter, turn it off.
Then, if you want to remove the battery, take a picture of your connections at the battery to help you next spring.
Thanks
