Black dripping Porch light gasket?
I think I will check the width of the mounting screws and see if I can match a RV Porch light that lines up with the holes. I've see ones that are dimmable on Amazon, so there may be other choices out there....Unless someone has done this already and can provide us with some details....please :-)
2021 T@B320 S - 2013 Ridgeline - Ont. Can
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming WOW! What A RIDE!!” Dr. Hunter S. Thompson
Took my light off again today and the sticker on the back side clearly shows the manufacture, see link.
https://itcshopnow.com/products/assurance-exterior-flood-light
Still debating on how to fix this.2021 320 BOONDOCK, 2017 F150 2.7 ECOBOOST1 -
I will be ether replacing mine or replacing the gasket with something else cut to size. Don't care about the original holes as long as the new light covers the old holes. I'll just fill them with epoxy.2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
I sent the mfg a note on this issue and they responded that it is the first they have heard of this. I sent pics that some have posted here(hope you don't mind) and indicated a few of us are having the issue. They promised to look into it and see if there is a solution.cyoung said:Took my light off again today and the sticker on the back side clearly shows the manufacture, see link.
Still debating on how to fix this.2021 T@B320 S - 2013 Ridgeline - Ont. Can
2 -
@Rodent77 thank you for contacting the manufacturer. Our 2022 Tab 320S BD has that black streaking from the porch light, too. Nucamp sent a replacement light but I do not want to bother putting it up if it will have the same problem. Looking forward to what you find out. Thanks again!1
Hi @BandB,
Any chance you can take a picture of the gasket? Just curious of thickness and shape before I remove the light. I plan just to make my own gasket out of silicone rubber or foam. Sounds like the light folks either didn't get what they asked for or specked out the wrong stuff.
Thank you2025 360 CS
Southern Maryland0 -
This is their response from the consumer support team "Thank you so much for the pictures and again for bringing this is to our attention. I will make sure these photos get seen by the right people, and hopefully we are able to come up with a solution! I will get back into contact with you when I have some answers for you! "
Hopefully they will come up with an answer soon.2021 T@B320 S - 2013 Ridgeline - Ont. Can
@Yoshi_TAB t
here's a slight ridge all around the gasket which the black plastic housing fits into. I forgot to mention that no screws came with the replacement light. The white wire is marked negative and the black wire is marked positive.
@BandB I wonder if that black gasket is a different rubber compound that is on the trailer. Let us know if they are when you replace your light please.
Hi,Rodent77 said:@BandB I wonder if that black gasket is a different rubber compound that is on the trailer.
Every sub supplier of a component is likely to supply a gasket material for their item whether it be a window gasket, outside outlet gasket, etc. There maybe some cases where NuCamp has to provide something such as their own gasket or sealant.
Outdoor gaskets are everywhere...my guess is the light folks either didn't get what they asked for or their supplier provided them an inferior gasket material not rated for UV, outdoor use.2025 360 CS
Southern Maryland1 -
I wipe mine off every once in a while. If it becomes a real problem I'll just make my own gasket and seal the outside edge with non-leveling lap sealant.
2025 Ford Ranger
This was the response from the supplier of the light. "We did look into the issue further, and this does appear to be a common occurrence for products on the outside of RVs and trailers. We would recommend using a good streak remover- that should help clean up those unwanted streaks. If you google "Cleaner for black streaks on RV" there are some different types of cleaners and videos with reviews as well. "
@Rodent77 - I received the identical response from the supplier. I do not want another one of their gaskets anyway. I found strips of EPDM rubber from Grainger https://www.grainger.com/product/APPROVED-VENDOR-EPDM-Strip-Std-1MYJ7 . EPDM, butyl and silicone rubber are supposed to have better UV protection:
https://www.swiftsupplies.com.au/news-tips-and-guides/uv-resistant-rubber-guide/
The strips are 2 inches x 36 inches x 3/16 in thick. They have different widths and thickness available. 3' more than I need but will fashion a template of existing gasket and cut a new gasket during the winter months. Rewiring will require further research.2021 320S BD
2020 V6 Chevy Colorado1 -
The part number for our 2023 trailer is 69711F-BK-AM. BK is for a black shell and AM is for amber LEDs. I just bought a two-pack of 69711F-CH-3K (chrome and 3000K white LEDs) for $15 from trailerfix on eBay.
The mounting screws are square drive. NuCamp used a very stiff sealant (probably styrene-butadiene like Shoe Goo) to mount the light and seal the hole for the wires. That makes it very difficult to pry the sealant loose enough from the wires to pull them through the hole. The fixture's gasket appears to be natural rubber, and it's not really the kind of gasket someone could craft (well) from rubber sheet. It's precision molded to fit a groove in the light assembly, and there's a raised rim around the outside shell for the light. There's white RTV sealing where the wires pass through the gasket, so replacing the gasket will mean removing the fixture's rtv and, of course, pulling the wires out through the wall. You can access the hole for the porch light and its wires by unscrewing the inside control panel. In our trailer, the thin wires for the porch light are crimped to heavier wires. The ground wire connects to a bus bar in that compartment and the positive wire connects the rocker switch for the light. To pull the fixture's wires free, I'll have to undo the butt connector crimps to the heavier wires inside.
There are many protectants and dressings for rubber and I treated the exposed edge with expensive 303 rubber protectant, but the edge is still eroding. I'm inclined to try painting the gasket with a rubberized paint like Plasti-Dip to prevent the rot.
Note the molded groove and raised rim of the gasket.
If you want to try and find a similar size light, this drawing with dimensions is from the ITC product page.
Utah-based
2023 T@B 320 S Boondock0 -
I bought a couple of these lights (chrome with white diodes) from ebay for about $15. Our 2023 trailer has a black shell with amber diodes. I removed the white silicone sealant to remove one of the gaskets and painted the edges with clear Flex Seal Liquid. But I decided to try and use the gasket already in place on the existing fixture. I removed the fixture and cleaned the eroded edge of the gasket with isopropyl alcohol. I also removed the residue of the stickers that were stuck to the gasket and the trailer wall.
Here's what the molded gasket looks like (with the sealant painted on):
After going through all this, I'd advise leaving the porch light installed and clean the exposed black gasket with alcohol until you you don't get a lot of black on the cleaning cloth. Then use a small brush to paint a sealant onto the rubber. A clear sealant would be a lot easier to apply with good looking results than a black one would. I don't know how well my choice of sealant will work over time. Right now the trailer is covered, so the proof will come after some months of exposure. All the black staining came from the thin exposed edge of the rubber. The unexposed rubber showed no signs of oxidation or erosion.Utah-based
2023 T@B 320 S Boondock2 -
Just a follow up.rfuss928 said:I cleaned the gasket off as best I could although it still would leave a black streak on the rag no matter how much I wiped. Then I covered it with a couple of coats of clear Polycrylic. I'll see if that holds up next season....
I never really thought about this again until this Spring as we got ready to hit the road. I looked up at the light and thought "I can see the Polycrylic around the edge I coated - Oh! and no black streaks". It has a bit different sheen at the right angle in bright sun. A bit visable at the lower left end of the light. Seems to be solving the problem so far. I did notice the black gasket around the wheel well trim does the same thing to cleaning rags. It just doesn't drip down the trailer side...
I have the same issue in my 2022 T@b 400 BD with the over the door light. Also I have a problem with the gasket around the external 110 outlet near the door. Black streaking off of it. I painted some silicone sealant around it, but not the light yet.
Sorry to see the manufacturer is not standing by their product. They need to get a different supplier for the gasket.2022 T@B 400 BD, the T@bacabana
TV: 2017 Chevy Tahoe0 -
Fixed mine from running with my wife's clear nail polish, 2 coats
2 -
Sounds like others found a much easier fix. I decided to fashion my own gasket during the winter from EDPM rubber which is supposedly more UV resistant. Wires accessible from the switch plate on the wall are easy to disconnect. Used old gasket as template and cut new gasket from 3/16" EDPM with box cutter. Black Shoe-Goo'd the gasket to the back of the light fixture and attached to the original location. Will see if the EDPM works any better.
2021 320S BD
2020 V6 Chevy Colorado0 -
I wound up replacing the whole fixture. I was just going to clean up the gasket edge with isopropyl alcohol and apply Capt. Tolley's. The fixture felt a little loose, so I thought I'd tighten the screws a bit first. I barely gave them a turn to snug them down and it cracked the plastic at the screw head. I ordered a new light from the nucamp store and installed it. I went ahead and applied the Capt. Tolley's to the gasket edge to protect it.
I keep my trailer covered when not in use, so I was surprised that the plastic on the light was so brittle.2021 T@B 400 BDL aka Little Joe
2019 Tundra Crewmax aka Hoss
SE Louisiana0 -
Inoticed the same issue on my 2022 TAB320S Boondock this past weekend. I will try the clear nail polish trick to see if it helps and go from there.2022 T@B 320S Boondock
2021 Toyota RAV4 TRD Off Road
Ottawa, Ontario, Canada
Instagram: new.t@bventure0 -
@Clifco and @Maple_Geek let me know how the clear nail polish works out. After 4 years of use our 2021 400's porch light finally started to have the dreaded black streak.2021 T@b 400 BD "Vixen Gail"
Leadville Colorado2 -
Works great, once you apply a few coats black streaks no longer happen
Great I'll give that a try!2021 T@b 400 BD "Vixen Gail"
Leadville Colorado0 -
same streaking, 2021 320s. Documenting the commonality of this issue. Not going to address anytime soon.
2021 T@B 320S Boondock/ 2012 Tacoma 4 cylinder truck / 2023 Tacoma 6 cyl. truck0 -
2021 T@B 400 - been putting up with cleaning the streaks and bit the bullet to address. The bottom of the screw holes in the white bezel was broken, as mentioned before, so rather than trying sealing the gasket I got a replacement from Amazon / Partsam and It fitted with minor work. It is a direct size replacement, just drilled a new 1/4" hole for the wire position, the mounting screws are the same position. The wires, in the T@B400 anyway, are assessable above the door. Looks good. See photo comparing old white bezel with the new black one and the gaskets - they are the same size, even if the photo appears as not.
Partsam 2Pcs 8” RV Porch Lights 12V IP67 Waterproof Utility Strip Lights Bar Surface Mount for Motorhome Caravan Camper Boat Marine Black Housing
2021 T@B 400 BD T@bitha with 2016 Highlander
Juliet and Andy in Massachusetts2 -
This black streak from light issue is happening on my 2025 T@b 360. How did the above mentioned sealant options work out? Not sure if I should try clear nail polish or a clear silicone sealant. It sounds like some silicone sealants won't adhere to the rubber. Thanks in advance!0
The clear Polycrylic coating I used 3 years back is still working preventing any streaking. A very simple fix...LauraC said:This black streak from light issue is happening on my 2025 T@b 360. How did the above mentioned sealant options work out? Not sure if I should try clear nail polish or a clear silicone sealant. It sounds like some silicone sealants won't adhere to the rubber. Thanks in advance!
