So, I realize that there’s head shaking at some of my mods. Well, here’s another one for you. Don't laugh too hard.
Last year I replaced the 3-way fridge in my 2020 320S with a 12V chest cooler on a pullout. To get the 3-way out required removing the screen door and the frame that it was attached to. I got the impression that the frame was backwards engineered when they found the screen door no longer fit the bulky blow molded new door and locking mechanism. While my new larger fridge cleared the door, it did not allow me to replace the frame that the screen mounted to.
A magnetic screen door worked well and got me though the summer, but I was looking for a better solution. The factory screen door was the same as earlier models except that pre-2020 it didn’t need the frame because the door was thinner, and the locking mechanism didn’t protrude into the cabin. In these installations the screen door was mounted directly to the wall (no extra framing). I considered purchasing a pre-2020 door, but not at the nearly $900 quoted from nuCamp.
The solution I chose was to modify my door to pre-2020
standards. The molded cover on the inside of the door was easier to remove than
I thought. Except for a couple of holes where they mounted the fire extinguisher,
the surface was in good shape even after removing the glue used to hold the
cover on. I painted it with dry erase paint so that we can use it as a white
board. The paint is drying, and I still need to work out the locking mechanism,
but here’s where the project is at so far.
edit to add:
Posting this mod here more for amusement than anything I think someone may want to duplicate. Enjoy!
"Just Enough"
Pacific NW
I like your confidence @Denny16, but I still have to figure out a way to latch it. Getting nervous about mounting something on the thin door and door frame. Not sure what it is in my head that makes me have to change perfectly good stuff. One more beer and maybe I’ll figure that out. Have a good night.
Edit to say, I should limit my posting to daylight hours.
I also like and agree with the entertainment aspect of doing various mods.
Nice job my friend, stay safe.
