What is the distance of the waste tank outlet to ground, 2021/22 T@B 400 BD?
subkron
Member Posts: 205
I'm looking for a portable holding tank and I want to make sure it will drain from the T@B correctly (the RV is not close to me to measure). The Rhino 15gallon tank needs 13" minimum.
2022 T@B 400 Boondock
South Jersey
South Jersey
Can't give you a number for the 400, but it's about 10" on our 320. We use a Rhino tank, but have to be on a slope so that the tank is downhill from the outlet. Not perfect, but it might work that way for you also.
I was hoping it work make it without finagling - maybe a 400 owner can take a quick measurement?2022 T@B 400 Boondock
South Jersey0 -
My guess is that your trailer being a 400 and a Boondock on top of that, it will work on level ground. The reason I brought it up the finagling is that depending on how out of level and in what direction your campsite is, there's a chance that the drain may end up lower than 13"
The TaB400 BD black/gray tank drain is 13” from ground to bottom of the drain pipe connector on a level pitch. On a sloped site, this could be less or more depending on the slope direction. Mine is on a slight slope (higher on the driver’s side) so the connector is 12” from the ground.
Yes, 13" on our 2021 T@B400 BD to the bottom of the drain pipe outlet.2021 T@B 400 BD T@bitha with 2016 Highlander
Juliet and Andy in Massachusetts0
