For newer T@Bs with the Lagun table
SLJ
SLJ Member Posts: 668
For T@Bs with the Lagun table...
Adding another table bracket by the door gives you a table you can use for more counter space.
A place to set things during the day you can easily reach from outside the door.
At night it gives you a headboard so your pillow won't fall off for those like me that sleep front to back (slides right into the bracket on end).
The big plus is you have somewhere not in the way to easily store the table at night!
2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York
    Denny16 Member Posts: 5,430
    That makes a good storage position and setup, very nice.
  • jkjenn
    jkjenn Member Posts: 6,425
    How did you get the table like that? (Bottom photo)
  • scott14
    scott14 Member Posts: 200
    Good question.   I was about to ask the same thing.
  • SLJ
    edited March 2022
    jkjenn said: How did you get the table like that? (Bottom photo)
    The plate under the table has a ridge that just slides into the upright. It's normally use to attach the upright post for storage to keep them together. Just turn the table up on it's end and slide it on.
    2025 Ford Ranger
  • jkjenn
    Thanks! I knew about thos but had com0letely forgot.
