For newer T@Bs with the Lagun table
SLJ
Member Posts: 663
For T@Bs with the Lagun table...
Adding another table bracket by the door gives you a table you can use for more counter space.
A place to set things during the day you can easily reach from outside the door.
At night it gives you a headboard so your pillow won't fall off for those like me that sleep front to back (slides right into the bracket on end).
The big plus is you have somewhere not in the way to easily store the table at night!
2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York
2025 Ford Ranger
2
That makes a good storage position and setup, very nice.
Cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.0 -
How did you get the table like that? (Bottom photo)SLJ said:For T@Bs with the Lagun table...
Good question. I was about to ask the same thing.
The plate under the table has a ridge that just slides into the upright. It's normally use to attach the upright post for storage to keep them together. Just turn the table up on it's end and slide it on.jkjenn said: How did you get the table like that? (Bottom photo)
2025 Ford Ranger
The Finger Lakes of New York1 -
Thanks! I knew about thos but had com0letely forgot.
