2023 tab 320s
Okpete
Okpete Member Posts: 45
Hello, how about update on 2023 tab 320.
    https://youtu.be/0JgM4qX6pDM
    Here is a recent nuCamp video from the Hershey, PA RV show.
  • Okpete
    Thank you. So the only change is the nautilus panel ?
    That is the only change that I have seen announced.
  • kottum
    kottum Member Posts: 226
    What is different about the nautilus panel on the 2023 Tab 320?
    Minnesota and Arizona
    According to the video, it has been changed to the P3 Nautilus like the 400s.  Further standardization.
  • MarkAl
    MarkAl Member Posts: 510
    Isn't the difference in P2.5 to P3 just the addition of the black tank valves & cleaning options?
    managed by VE Smart Network
    Denny16 Member Posts: 5,430
    Also, the Alde bypass valve is part of the P3 system.  On the P2.5, the Nautilus, the Alde bypass valve is separate, off to,the side of the panel.
    @MarkAl - the Nautilus is somewhat customizable.  Since the 320 has a cassette toilet, no need for a black tank flush, but they may include the outdoor quick connect shower like the P3 in the 400.  We’ll see…
    Yes, the TaB320 Nautilus P3 panel has the black flush port blanked out, and had the plug in outdoor shower hose connection as shown below.  Note the red valve in the middle is the Alde Bypass valve, and vertical is the normal position, horizontal is bypass mode.
    2023 TaB320 Nautilus P3 panel.
  • DLang4129
    DLang4129 Member Posts: 1
    We will be picking up our 2024 T@B 320 S BD/Black Canyon/Lithium Upgrade next month. We like the Nautilus P3 that we have used on our 2022 T@B 400. I stand on the shoulders of many of the great members of this T@B community, nüCamp and B&B Molders who have helped me understand how the slick P3 system works. Attached is a personal guide that I put together with all of their input that attempts to summarize how the plumbing works for the various scenarios listed on the P3 panel. Hope this is helpful to others! Cheers, Doug
    2024 T@B S Boondock/Black Canyon/Lithium Upgrade
    2020 Subaru Ascent Limited w/ trailer stability assist and break controller
  • EasternJL
    EasternJL Member Posts: 108
    Curious -- what's that red rocker switch for?-- the one below the white pump switch.
  • sailgeek
    sailgeek Member Posts: 5
    In the 320S, nothing.  Its not connected to anything from what I understand.
