2023 tab 320s
Okpete
Member Posts: 38
Hello, how about update on 2023 tab 320.
Thank you. So the only change is the nautilus panel ?
That is the only change that I have seen announced.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
What is different about the nautilus panel on the 2023 Tab 320?Douglas and Cheryl both Navy Retired
Minnesota and Arizona -
According to the video, it has been changed to the P3 Nautilus like the 400s. Further standardization.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Isn't the difference in P2.5 to P3 just the addition of the black tank valves & cleaning options?Snohomish WA, 2015 Diesel Grand Cherokee
managed by VE Smart Network -
Also, the Alde bypass valve is part of the P3 system. On the P2.5, the Nautilus, the Alde bypass valve is separate, off to,the side of the panel.
Cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast. -
@MarkAl - the Nautilus is somewhat customizable. Since the 320 has a cassette toilet, no need for a black tank flush, but they may include the outdoor quick connect shower like the P3 in the 400. We’ll see…Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Yes, the TaB320 Nautilus P3 panel has the black flush port blanked out, and had the plug in outdoor shower hose connection as shown below. Note the red valve in the middle is the Alde Bypass valve, and vertical is the normal position, horizontal is bypass mode.
2023 TaB320 Nautilus P3 panel.Cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast. -
We will be picking up our 2024 T@B 320 S BD/Black Canyon/Lithium Upgrade next month. We like the Nautilus P3 that we have used on our 2022 T@B 400. I stand on the shoulders of many of the great members of this T@B community, nüCamp and B&B Molders who have helped me understand how the slick P3 system works. Attached is a personal guide that I put together with all of their input that attempts to summarize how the plumbing works for the various scenarios listed on the P3 panel. Hope this is helpful to others! Cheers, Doug
2024 T@B S Boondock/Black Canyon/Lithium Upgrade
2020 Subaru Ascent Limited w/ trailer stability assist and break controller -
Curious -- what's that red rocker switch for?-- the one below the white pump switch.
In the 320S, nothing. Its not connected to anything from what I understand.EasternJL said:Curious -- what's that red rocker switch for?-- the one below the white pump switch.
- 917 Introductions
- 405 Service/Maintenance & Recall Notices
- 74 Teardrop Groups & Links
