Lead Acid to AGM
2015 T@B 320
Question: Can I simply change my old lead acid battery out with AGM? No concerns with charging system in camper?
Thanks
Don & Michelle
2015 T@b S.  2017 Nissan Titan
  • AnOldUR
    AnOldUR Member Posts: 1,762
    edited April 2023
    The WFCO converter will be fine, but you may want to check with your battery manufacturer for the best setting of the MPPT solar charge controller.
    edit:
    Guess I type too slow. @VictoriaP beat me to it on your other thread ... =)
  • VictoriaP
    VictoriaP Member Posts: 1,496
    Shouldn’t be an issue. If you have solar, you may need to check the settings on your controller, but as far as the converter on the trailer goes, no changes needed.
    Pacific NW
  • Mickerly
    Mickerly Member Posts: 514
    Agreed. No changes needed to trailer.
    2018 320CS-S
    "Just Enough"
  • YanniLazarus
    YanniLazarus Member Posts: 371
    You might consider getting a Noco genius or similar charger to occasionally maintain and fully charge your new AGMs for better performance and longer life. Not essential... just better. And no change to trailer as wished.
