Alde convector locations
Sweetb
Quick history(but lengthy post ☹️): I posted to FB Owners page in early March that Truma service center(Lakeland FL) was unable to perform a scheduled glycol flush on our 2021 320S due to a significant blockage in the system due to “excessive corrosion”. By snaking from the tank behind toilet and a midpoint access, it was determined the blockage was located beneath the wet bath floor. Been trying to schedule a service appointment with local Nucamp recommended dealers. Finally have a tentative appointment for May 18. (Tentative because they don’t even have a pump to perform glycol flush at this time 🙄.) I’ve done numerous searches but unable to locate a schematic of the Alde system in a 2021 320S. Thought I read somewhere that there is a convector beneath the bath (where our blockage appears to be). Can anyone confirm this or point me in the right direction to find the answer?
Second question-has anyone removed the wet bath floor? Probably won’t go that route-but gathering information. 😉 Thanks.
@Sweetb - here is what under the shower floor looks like: https://tab-rv.vanillacommunity.com/discussion/5025/just-fyi-on-what-is-under-the-shower-toilet-floorSharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Hi, I have 2021S and there is a convector in mine behind the toilet removable panel. If you remove the panel and look down you can see it. It seems smaller than the others. Best wishes.2025 360 CS
Southern Maryland0
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
