2014 CS-Owner cannot find glycol drain under trailer.
pthomas745
pthomas745 Administrator, Moderator Posts: 4,569
FB thread with owner showing us pictures of all the drain spouts under the trailer.  None of them have a plug.  There is glycol in the expansion tank.
Tested the hot and cold water drains, etc.
Where would NuCamp hide a drain plug for the glycol in a very early Alde trailer?
    If it is not under the driver side  bench area, tell them to check near / under the driver side in front of the wheel under the reservoir tank.
    Ouch!  Thanks so much.  Did not think this one through!
  • fstop32
    fstop32 Member Posts: 391
    My 2015, though not a CS, has the glycol drain about 16" behind the driver side wheel.  That's also near where there is a plug holding 3 - 1/4" drains for water and overflow from glycol expansion tank.  The plug on my drain was not all that noticeable with road mud and crud on it.
    DaveR middleTN - 2015 320S  /  TV 2003 Tundra 4x4
    ScottG Administrator Posts: 5,669
    Perhaps they could find it from the inside. It's a smaller diameter T molded into one of the glycol hoses and extending through the floor. It's not exactly obvious, but there should be a fitting on either side where the drain is fitted into the main line. If you pull up on the hose it becomes clear there is a piece sticking through the floor.
