Installing a Victron Battery Monitor
I have a 2017 320.  I am interested in monitoring the battery for state of charge and the time remaining on the charge. Has anyone installed a Victron battery monitor in the battery/propane compartment?  It looks like the metal plate on the front of the camper would be a good spot.  I am not sure.
  • Marceline
    Marceline Member Posts: 1,773
    There are two versions of the SmartShunt. The less expensive version (IP21: 500A) is absolutely not waterproof. If you install it on that wall, chances are it will get wet from either water running down the leading edge of the camper or water splashing up from below it. I installed mine inside the plastic box that encloses my battery.
    The newest version (IP65: 500A) is "water resistant" which is still not technically waterproof.
    Personally, I'd try to figure out a way to install it in a waterproof enclosure.
  • VictoriaP
    VictoriaP Member Posts: 1,496
    edited July 2023
    When I installed my shunt, I opted for an electrical box off Amazon, two Blue Sea mini bus bars, and a bit of industrial velcro beneath that holds the electrical box to the top of the battery box. No water issues. A velcro strap holds it closed while giving me easy access to everything in case something fails. And the whole thing is easy to remove when the time comes to replace the battery.
    (Yes, there’s currently red electrical tape on the trailer negative cable, was unable to find the black among my tools at that time. Need to fix that!)
    Pacific NW
  • Red_Rover
    Red_Rover Member Posts: 19
    Wow, that is pretty cool. I see that your container enclosure is made out of steel.  You can see that I have the fiberglass standard enclosure.  Who did you buy your enclosure from?
    pthomas745 Administrator, Moderator Posts: 4,667
  • VictoriaP
    edited July 2023
    The aluminum diamond plate propane tub is standard on Boondock models; pictured is the pre-2021 version. Post 2021, the shape is a little different. You can buy them from any Tab dealer.
    The black battery box & white electrical box are both plastic.
    Pacific NW
  • BrianZ
    BrianZ Member Posts: 1,770
    @Red_Rover,
    One of the links above shows my victron shunt box installation in the tub.  I later added a second similar box for bus bars, to clean up all the wires going into the battery box..
    https://tab-rv.vanillacommunity.com/discussion/comment/106983
    Everything still works great, and as noted in my writeups, I also used a waterproof coating on the shunt electronics to help protect from water vapor condensation.
    -Brian in Chester, Virginia
    RV: 2018 T@B 320S, >100 mods
  • ChanW
    ChanW Member Posts: 3,165
    I followed @BrianZ's lead, with the handy junction box in the tub, for our shunt.
    We have the older model battery monitor with the display, so I also put that display in a waterproof box, and left it in the tub (not much need for it with the Bluetooth phone app).
    Denny16 Member Posts: 5,430
    Nice nice job Chan, looks like a very neat install.
  • webers3
    webers3 Member Posts: 436
    Here it is in my 2017 320, installed on the AmperTime battery, works great
