We have a 2022 320S. We replaced the lead acid battery in the tongue tub with a marine grade, 206 amp hour lithium battery. On a 3-week trip we camped between 4,500 and 8,000 ft. (Eastern Sierra’s). A short colder system came through and the temperatures dropped to cold rain 1night, then an overnight 2inches of snow. The Alde and fridge shut off in the middle of the snowy night, and we realized the battery was not working. Thankfully the 320 only dropped to 58 degrees inside. The storm was short lived, but our next campsite was still dropping to 31 at night. All day Solar was not bringing it back. It would try, but would shut off in just several seconds turning the water pump on. Another night without heat. We drove home 8 hrs, and the battery went up to 13.1V. Then we plugged it in at home, before taking another trip at sea level and no colder than 48degrees. The Alde and fridge worked fine. We are thinking that the solar is not giving us a full charge. We already have shoved packing foam around the battery thinking it would help insulate it from cold. Since this didn’t work, what else can we do? We are not capable of moving it inside ourselves. Before we decide to pay someone to move it, what suggestions are out there? We’re thinking about adding some kind of heating, maybe a pad. Sounds like the propane tank would like to be warmed too. Anyone else solving this dilemma?
0 ·
A couple of questions if you happen to know; 1. Was your battery fully charged when you left on your trip? 2. How many days into your trip was it when the Alde and fridge shut off? 3. What was the outside temperature during your trip before you lost power? Depending on your battery BMS, it may have shutdown charging if the temp. was below the shutoff threshold. At that point, you would not get any charge from the solar, even if there was full sun. 4. Do you have a smart shunt and can provide any historical data up until you lost power? Can you provide any screen shots from the solar history ?
As @Grumpy_G, says, adding heat wraps is easy, but any device that produces heat, especially electrical heat (either 12V or 110) will be a energy hog.
Southern Maryland
We recently camped at about 7000ft with lows in the 30s. One night it got down to 20. I have a Victron Battery Sense on our 100 ah Lithium battery that is in the front tub in a lightly insulated box. The lowest temp the battery ever got was 3 deg C (37 deg F). I doubt your BMS hit the low temp cutoff, and even if it did, it would have warmed up enough during the day to allow the solar panels to charge. But again, with the low solar angle you probably never gained back what you lost. And the Victron solar controller requires the solar output of the panel to be at least 5 volts more than the battery to kick in so that was likely a limiting factor as well.
You could get more solar capacity, like a portable suitcase, or perhaps a small generator. I have a DC-DC charger mounted in the tub and I could hook it up to my truck and run it for a while if need be. It's a challenge to go on a 3 week trip and keep everything going - even more so this time of year!
2017 F-150
Coeur d'Alene, Idaho
2013 CS-S us@gi
@KC_Camps, you asked about heating pads. Heating the exterior of a lifepo4 battery case with small silicone heating pads is a very viable option. We used to have a 200ah lifepo4 battery we exposed regularly to sub-freezing temps. Heated this battery using 4, 80x100mm 24w silicone pads wired series/parallel so they only drew 2a/12vdc (24w) of total current. They were able to maintain the battery/cells between 45-50f (via thermostat) when exposed to ambient temps as low as 0f. For what it's worth, 2a (24w) is the typical parasitic/no-load current for many 2000-3000w inverters, so a very low draw comparatively speaking. Also, keep in mind the pads would not operate on a 100% duty cycle (2ah consumption) unless ambient temps were near 0f. With higher ambient temps (i.e., 15-20f), overall consumption would typically drop below 1ah---roughly equivalent to turning on a couple of lights inside our 320.
If there hadn't been available space in our '23 320's passenger-side wheel well, we wouldn't have hesitated using heating pads to keep our new 304ah lifepo4 battery warm in the front tub. However, for us, relocating the battery to the passenger-side wheel well offered a number of advantages that went beyond just protecting the battery from extreme temperatures. It: 1) lowered our tongue weight, 2) provided the opportunity to replace/shorten the excessively long OEM battery/battery-disconnect/power-center/converter wire run---significantly reducing voltage drop, and 3) allowed the battery to be located next to our inverter/charger significantly reducing cable length and costs. Even with the battery located inside our 320 . . . we still installed heating pads just to cover every eventuality.
2023 T@B 320 S Boondock
Marine Grade 12V 206Ah LiFePO4 Battery,Sealed Plastic Box
One of the "learning curve" items is the fact that a lithium battery will be damaged if you try to charge the battery when the actual physical battery cells are below 32F. The SOK has a "low temperature charging protection" circuit on the battery that will shut down charging when the battery reaches 32F. That may have been one issue on your inability to charge. Your idea of insulating the battery is a good one. It will help.
2020 Honda Ridgeline RTL (AWD) Lunar Silver Metallic
North Texas
Trips - 45 Mileage - 57,106
