Do I have a Boondock??
KellyG
Member Posts: 11
Hey all. I have a 2018 T@B 320 S. I purchased it in 2018 or 2019 from an RV shop where it had been traded in shortly after purchase. As far as I know it is not a Boondock model. BUT, the tires always seemed like they looked like Boondock tires. I decided to take my T@B out of the campground where it has sat for most of the time since purchase so I can take it on retirement adventures and figured I needed to put on some new tires. Checking my tire size, and Westlake ST235/75R15 is the boondock tire size. Silly to ask after this long, but do I have a Boondock model?? What else is different that would answer that question?
Kelly G
2018 T@B 320 S TV: 2020 Kia Telluride
(T@B is New to me as of 8/30/2019)
Bloomington, IL
Bloomington, IL
Your tire size "R15" is the tire size used in 2018 on the Outback (Boondock) model . . . . and also on standard rigs that had the "pitched axle" installed as an option . . . back in 2018 nüCamp was very flexible allowing for customer requested changes.
You could also measure the coupler height ( 'B' in figure ):
BTW, I have a special order 2018 . . pitched-axle, R15 tires, and front storage rack'18 320 S, pitched axle, 3020HE; PNW based
Adventures: 50 Nights: 415 Towing Miles 50,6501 -
Should add that I don't have the other obvious things like a roof rack or diamond plated boxes.Kelly G
Bloomington, IL0 -
The floor was obviously different in the 2018 Boondock model. Factory specced Boondocks had slate grey Marmoleum flooring, while non-Boondocks have a brown, wood-look vinyl.
The roof rack, tubular front platform, and aluminum front tub were also obvious features of that model. As MuttonChops mentioned, it’s not uncommon to find older Tabs with a mix and match of features as nuCamp was much more flexible about customizations. Plus, a lot of folks retrofitted these features themselves later on as parts became available.2019 320s BD Lite, white with blue (“Haven”)
Pacific NW1 -
If the previous owner retro fitted a pitched axle, would the step height to ground be different?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Yes Sharon, it would be. We added the pitch Boondock axle to our TaB, and had to get a small step stool to make up the difference in height.
2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.1
