2017 320 CS air conditioner needs charging
We typically camp at altitude or w/o electrical or water/sewer hookups (live in SE Colorado) so we have never used our a/c unit since buying it used in 2021.
However, a college reunion in Oklahoma - and eye popping motel rates - led us to an RV park, just in time for 108 degree temps.  We survived by opening the side windows, cranking the vent fan on high... and sweating a lot.  Cold front arrived in the wee hours thankfully?
How do we charge our little Kenmore Model 253.87050?  Says "R410A: 10.58OZ" on the label.  (This was a rental T@B before we bought it in 2021 from the previous owners who bought it from the dealership, if that makes a difference.)
TIA,
Mike & Becky
  • Grumpy_G
    Grumpy_G Member Posts: 789
    You don't, you buy a new one. These are run-of-the-mill window air conditioners which are typically the same size (just check to make sure).
    If the A/C unit lost its charge it has leaked out so recharging alone it won't fix it.
    edited June 2024
    A 5000 BTU Frigidaire has been a popular replacement as it has a digital thermostat.  If you go this route, read up on how to optimize the air intake and outflow using deflectors as well as insulating around the inside trim.
    https://tab-rv.vanillacommunity.com/discussion/comment/47252#Comment_47252
  • mmcneil72
    mmcneil72 Member Posts: 48
    Thanks Sharon!  Depends on how much warm weather camping we do this year (likely not much).  Various other repairs/mods first in line.
