2020 T@B400 Boondock Lite (Solar), purchased Sept 2023
Harris Battery, AGM, 2 x 6V batteries
I just returned from a trip to Colorado and Utah where on 3 occasions I boondocked at National Parks for 1 night. The only measure of battery strength I had, was the panel display(yes, I know it is not reliable). Within 1 hour of setting up camp, the display indicated battery was low. Also, when I tried to use propane setting on the Alde for heat, a low battery warning alert displayed.
Today, at home I turned off the battery switch and used a multimeter to test battery. Everything was turned off in the camper. The reading I got was 13.7, which I know is NOT accurate. How do I get an accurate battery health reading? Do I have to disconnect the converter/charger? If so, how?
Bernadette / 2020 (8/2019) T@B 400 BD / 2023 Honda Ridgeline / St. Louis region
To determine capacity the battery needs to be fully charged then a known load applied and timed while state of charge is monitored. Generally best accomplished on an analyzer at a battery shop.
Depending on use and care, 4 to 6 years is common life expectancy of AGM batteries. The OP batteries fall in this range.
AnOldUR - AGM batteries do not require venting.
Everyone - thanks for the feedback. I have no problem replacing the batteries, if necessary. What is the purpose of the chart below that I copied from a post on this forum? I thought this chart showed battery health.
Voltage
Capacity
13.00V
100% (charging)
12.85V
100% (resting)
12.80V
99%
12.75V
90%
12.50V
80%
12.30V
70%
12.15V
60%
12.05V
50%
11.95V
40%
11.81V
30%
11.66V
20%
The chart shows the state of charge (SOC) vs measured voltage, it does not indicate battery health. It's not a very useful chart in my opinion because different batteries behave differently. I have some old batteries sitting around that "recover" to over 12V after dropping below 10V under load.
2020 Tacoma TRD Off-Road
