Need fresh water tank for 2015 320 CS-S
We need to replace our freshwater tank. Our service agents haven't found one. Any suggestions? Is there a graveyard for T@B trailers?
    Have you contacted a  NuCamp dealer to see if they have one to sell you?
  • Grumpy_G
    Grumpy_G Member Posts: 787
    Most likely the water tank is an off the shelf product, just like many other components. If you try to take some measurements you might be able to match it to a tank from an RV supply or even Amazon.
  • Miwok
    Miwok Member Posts: 19
    This 2015 is a pre-NuCamp (Pleasant Valley) -- no help coming from NuCamp so far. I have an extended warranty, so now trying to work out how to manage a 3rd party product and another party installation on warranty. Learning a lot. All advice welcome.
  • rfuss928
    rfuss928 Member Posts: 1,196
    edited November 2025
    From ~2012 on all T@Bs have been built in Sugarcreek OH by Pleasant Valley Trailers / NuCamp.
    I would be surprised if they stocked any specific parts for a 10 year old trailer.  There may be someone in customer service that could find specs or possibly a drawing.
    I would search for a standard tank with similar capacity and dimensions. There are lots to choose from even at a specific capacity. Expect to have to add some custom holes and fittings.
    A good RV repair shop should be able to help or advise.
  • Miwok
    Still on the search. The tank is 36x20x4". No one seems to make such a thing.
  • Bayliss
    Bayliss Member Posts: 1,534
    @Miwok, have you tried contacting "Plastic-Mart"?
    They make RV fresh water storage tanks and holding tanks.  Maybe they can make one to match whatever dimensions you need.  If not, maybe they can refer you to someone who will.  Good luck!!
    https://www.plastic-mart.com/storage/    (866)-310-2556
    Greg & Marlene (Tucson, AZ)
  • GaryStebbins
    GaryStebbins Member Posts: 3
    Years ago I needed a replacement tank for my sailboat. Ronco Plastics had many sizes of tanks and placed appropriate fittings for me for no extra charge. I'd check there.
    2020 NuCamp T@B 320S Boondock
    1995 Suburban :-)
